Could I run these sizes without causing any issues with the awd? I found a couple threads where someone was runnin this size but with a 2wd. I compared sizes and there's about .360 difference.
Thanks for any advice!
It's a little over 1% difference. It should be fine since no one can quite pin down the exact tolerance of the AWD system. Some say 1%, some say 2%, Nissan says 0%. But you could get to a 1% difference through tire wear, so the system has to have some sort of tolerance in it. I would say a 265/45 up front would be better since that will have a variance with a 295/40 of only .4%. I've personally run 265/40/22 up front with 285,295,305/35/22"s in the rear with no issue for the last 26K. All of those differences were under 1% and I never triggered a slip light and my transfer case hasn't exploded yet.
wow thanks alot for the link. i like the 06 thread pattern more then any other tires. gonna wait till spring before i jump on tires. give myself a window to find a set of rear gtrs :PI got them from www.discounttiredirect.com a couple months ago. I had heard they were no longer made, but have never not been able to get them. I've also ordered from stores on eBay.
do they make the rh06 anymore? cant seem to find them at major online retailers.
