Ataher
- Tripoli - Libya
A helpful way of knowledge sharing used widely in my domain, which is a list of key Do's and Don'ts that are golden rules specially for new comers and fresh recruits, and handy reminders for the seniors, they are useful in avoiding problems (mostly catastrophic) by people obeying them even without knowing why still, which is a great learning method (stop and think), you could add why and why not. These are obviously lessons that were learnt mostly the hard way.
Typically recommendations and common sense items are excluded to avoid having long lists. The best way is to try not to make one up or think hard to get one, just share what you have done once and it was a bad call.
I thought if we establish something similar, it would be a great asset for this forum, here are some examples:
- Do disconnect the negative terminal of the battery before carrying out any maintenance on the car specially when you do not need power (such as changing brake pads .. Etc ), some warning lights might pop and stay on.
- Do not use impact wrench on DRM spacer lug nuts as stated by manufacturers themselves, studs might break lose jeopardizing the integrity of the structure.
Sent from my iPad
Sent from my iPad
