Click sound
LEXFX
NY
2004 fx35
I hear a click when braking/coming to a stop and also accelerating on front area by driver side? Or front pass side? What could that be? It started few mos back when I had my rotors installed and then now when I just got my calipers painted,
Is the sound metal on metal? Could be the ujoint/driveshaft. The noise i had was only happening at certain low speeds. I posted some clips in the thread under the engine section (knock or clank). Not enough posts yet, to give you the direct link.
Thanks everyone, found out that it was the calipers, some clip off of it was making the clicks, cleaned it up and installed properly so now no more clicks.
but now I found out when they lifted the car that I need to do my rear engine oil seal that's where my oil was leaking $520 total incl oem seals with labor
there is a DIY on here that you can perform on your own and save money, or you can go to a local mechanic shop and they will do it for less (sometimes showing them the DIY)makes it easier for them..
---------- Post added at 11:00 PM ---------- Previous post was at 10:58 PM ----------
here you go
https://www.infinitiscene.com/search/1/?q=13716-Oil-Cooler-DIY
I did that already, and this time it's leaking from the rear engine main oil seal and a little bit off the drain plug, it's not leaking drastically but mild. But I'm getting it done next wk. I still have full oil, just added one quart, I lost about 50% in 500 miles
---------- Post added at 10:41 PM ---------- Previous post was at 10:41 PM ----------
Yo lex I told you should not had paint the calipers hardware lol
Lol you know me! Smh lol
