DIY: install GTSPEC Strut Tower Brace (STB) on a 2009 FX50 | time: 1-2hr
note to newbies: dont jack up ur car or let be jacked up while doing this mod, your strut assemly will fall
Good point Dracula, the car should not be jacked up, it should be on level ground when installing the stb, also remove that round plate so the 3 top strut nuts have full engagement on the three bolts.
how level does it the ground have to be? finally gonna try to put this on after the strut bars been sitting in my closet for a year. My garage is slightly inclined will it be a big problem?
That will not be a problem, it can be a problem if one side is higher than the other or jacked up on one side.
You will be fine.
Good to see you back on the board :good:
You will be fine.
good to know! I will attempt this when the sun comes back:smile (2): Good to be back too, be neglecting on the car modding and attending to my other hobbies. Got my rims repainted yesterday and here I'm back on the board lol
