Camshaft Sensors
Dr.2K
iS Doctor on Duty
iS VIP
Santa Clarita, CA
2005 FX45
Hey, does anyone know where the 2 camshaft sensors are located on the 45?
Anyone have a diagram handy? I know there is the crankshaft sensor by the bell housing.
But where are the 2 camshaft sensors for bank 1 and bank 2?
Cam sensors are normally right under the valve covers either in front of the engine or back of engine. Should be easy access to. I haven't found a hard to reach one yet on a Nissan.
I've been searching the FSM for 20 minutes and can only find one Camshaft Position Sensor.
///9276[/ATTACH]
///9277[/ATTACH]
Not sure....
I think that's for the VQ35 Jeff. I have the picture/location for the cam sensor (phase) at the front of the engine under the cai housing, but unsure of the other ones location.
I can only find one Camshaft Position Sensor on the VK45DE also.
I also look that the same diagram Jeff posted. Its for the VK45DE engine. The VQ35DE engine has two.
---------- Post added at 08:43 AM ---------- Previous post was at 08:36 AM ----------
VQ35DE:
VK34DE:
Thanks Jefferson.
The reason I ask is I just had the crank sensor replaced at the dealer with part #senso-23731-4M50B. Which is the second one.
I had the camshaft sensor for Bank 1 replaced 3 years ago and I looked at my service invoice and it had the exact same part number.
I asked the service tech about this and he told me that for the FX45 the 3 sensors use the same part. But the VQ engine is a different story.
I just want to double check independently and also want to go ahead and replace the camshaft sensor for bank 2 while I'm at it. Which I believe I can do at home.
Thanks Jefferson.
Crank and Phase sensors are the same part number 23731-4M50B
And both Cam sensors are the same part number 23731-2Y52A
* part numbers based on your 05 FX45 *
Thank s Jefferson!
---------- Post added at 08:34 PM ---------- Previous post was at 10:34 AM ----------
But even if the cam sensors and the crank and phase sensors have different part numbers, could it still be the same exact part?
Thank s Jefferson!
They look like they could plug in to each other, but they are not the same part
///9293[/ATTACH]///9295[/ATTACH]///9294[/ATTACH]
*23731-4M50B and 23731-4M50A are the same part,one supersedes the other*
Thanks for clarification Jefferson!
Hmm....So maybe I had my cam "phase" sensor replaced 3 years ago and not the camshaft sensor along with my "crank" sensor last week, as the listed part numbers are the 23731-4M50B. Will buy the other 2 cam sensors and keep it on hand if this happens again.
I am surprised I have not seen others report this situation with the FX on the 45 or 35. Hope this helps others in the future.
Hey Dr.2K
I remember you from years ago when I was more active on the forums. I still have my 05 45. I need to fix a sensor issue. I am starting with replacing bank 1, if that does not work I will move to bank 2 and then crank shaft. Any advice as you have done this? Right now I am just trying to get the right sensor for the best deal, but I am struggling with figuring out if the cheaper ones I see are actually crans shaft sensors, not cam shaft...
JAB
