It could still be the actuators. Mine went out and I have an 04 also. I got them replaced by infiniti, not sure if it was under some sort of warranty. They could still work somewhat, but not push the locks all the way in and out, hence you still hear the noise but the do not lock/unlock.
Well, I bought the car from Honda and a day later I realized they didn't work. Brought it into Honda and they gave me a loaner and said they would bring it to Infiniti to see what they would do as Honda didn't want to cover it. They took it to Infiniti and apparently they replaced all of them at no charge. Not sure how all of the deal went down but I got them at no charge regardless.Hi, your car is an 04 and you got it replaced at no charge from the dealer? Mine just started to act up. I can here it trying to lock and unlock. It's mainly the front doors but then it started not working for the back. This is has come and gone. I guess I need to check the fuse and maybe change the battery???
Ataher - Yeah, this problem comes and goes depending on the weather. It just started happening last week. Most the problems are in the front. Most days it's both driver and passenger side. One day it's one of the other. Think once it was all of the door. Using the remote I can hear the door lock beeps and it trying to unlock/lock. Geez, $220 each door for parts only. How long does it take to replace for each door for DIY?
blackfx- lucky you!
