STILLEN Underdrive Crank Pulley or Unorthodox Underdrive Crank Pulley for FX
STILLEN Or Unorthodox Underive Crank ?
  • STILLEN Underdrive Crank Pulley
    Votes: 1 16.7%
  • Unorthodox Underdrive Crank Pulley
    Votes: 5 83.3%
  • Total voters
    6
wrxsti04
NC
FX
So you guys have been my help and deciding factor for purchase so here it goes:
I am stuck and can't decide if I should get my Underdrive crank pulley from Stillen or Unorthodox?
I've searched our forums, nothing. I searched 350z forums and nothing concrete.
Both are around the same price with belts. The Stillen seems to be slightly lighter than Unorthodox.
Unorthodox has good reputation for pulleys but STILLEN has good reputation in aftermarket for Nissan/Infiniti?
Stillen list a lot of details on the crank pulley on their site while Unorthodox is somewhat vague and does not specify belt brand/type
Makes for tough choice
STILLEN Pulley Weight: 1.28 lbs.
Belts: STILLEN Gates Underdrive Pulley Belt Set
http://www.stillen.com/product/pull...350z--g35-4dr--0307-g35--03075-fx35-8142.html
Unorthodox Pulley Weight: 2 lbs
Belts: Bando ?? Not clear does not specify.
http://www.unorthodoxracing.com/pulleys/crank-pulley-4723.html
Both are probably the same in terms of quality. It's just a machined part and both companies have a lot of experience with it (UR has been doing it for a little longer). I'd personally get the UR just because I would feel better with it after an crappy experience with a Stillen SC kit on a former car and the issues it had with pulley alignment and shredding belts. This was a decade ago though, so I'm sure they've improved their standards.
I go with UR again, just because I have an set in my 35 right now :smile (2):
LOL Andy I got your verdict from the last post thanks for the input as always!
So there is no worry about the quality of belts from UR's Bando vs Stillen Gates ?
I got Gate when I order mine from the site that I bought from. I'm pretty sure the quality is there in both, just a matter of preference. I have use some generic brand I pickup from Napa and they work just as well too.
This is correct I received the Gate Belts with the Unorthodox pulley I ordered and received today. Hopefully should have it on in week or so.
---------- Post added at 12:30 AM ---------- Previous post was at 12:27 AM ----------
UR is great.
I have a CNR crank pulley (UR copy) (stock-sized) sitting in my house if you want to buy it for cheap.
Thanks but already ordered UR Crank
---------- Post added at 11:53 AM ---------- Previous post was at 12:30 AM ----------
In case anyone needs the belt part numbers here they are. http://www.conceptzperformance.com/ did send belts with the crank and verified they are all correct.
underdrive Crank FX
Alternator, Power Steering and Idler Belt - Gates K060441
Air Conditioning Belt - Gates K040347
stock size Crank FX
Alternator, Idler & Power Steering – Gates K060465
Air Conditioning – Gates K040372
Just got the pulley installed today will report back in week once ecu has realized the change. They put the stock pulley in my UR box man is it heavy compared to the UR
