Need help on what coilover n spacer to get...help please thank u
C LO
BROOKLYN , NY
I HAVE A 04 FX35
I can hook you up with some BC coilovers and H&R spacers. PM me for more details.
If you get BC's, make sure to get upgraded spring rates, the stock ones are too soft IMO. If you don't drop too much, it's fine. But if you slam it, you'll have to crank the damping way up. That's what I do right now on BC's and am researching stiffer springs.
Shadow, if you need springs for BC's just let me know. I can get any rate you want.
+1 RE: Stiffer spring rates, also the rear wheels will camber in as you drop, suggest you confirm your drop/camber before you purchase the rear spacers (assuming you are hoping to achieve "flush")
I have the BC with Ichiba V2 30mm spaces. I also had to use a camber correction kit on the rear wheels. My wheels poke out a little bit which gives it a more aggressive stance.
Hi zebra, I don't have enough post counts to send you a PM so hopefully no one objects to me posting my question here?
I saw one of your posts stating you could get BC coilovers and also supply different spring rates? I have an 03 FX45 with about 126K on it with H&R springs and OEM shocks/struts. I think it's about time for me to replace the suspension and I am considering going to a coilover setup. Can you give me a price for the BC's and the choices you have for the spring rates? Hopefully I can accept PM's.....
Thanks
I wouldnt mind knowing this too
What's the pricing on new springs?
PM'd
Thanks
email sent
Anyone with a FX45 have recommendations on springs rates, as most feel the 8kg/12kg setup is too soft? I saw one person who went with 12kg/12kg which i could understand due to the weight of the V8. But what about 12kg for the rear? I thought in some other posts people felt the back end still "walked" during hard cornering? Any help/thoughts would be appreciated.
