roadracer516
For a winter package: 265/60-18 tires mounted on 18 x 8 / +30 offset G35 coupe wheels?
I was in the same boat as u trying forever to see if this or that would clear. Then I just went and bought the 1 setup that I know clears for sure. I'm pretty sure I posted the details in my jdTrader thread.
It's not the width or clearance from suspension and fender you need to worry about. It's whether or not the 18" rim will clear your caliper. I'm leaning toward no; I'd do a search on 1st gen guys who installed the Akebono brakes. I believe that the OEM FX 18"s won't clear and if that's the case, I doubt the OEM G wheels would clear either.
Edit: NVM, I believe the 18" G coupe wheels will fit. G sedan won't or would require spacers.
