GaylordRN
- Philadelphia
Are there only two belts that need to be replaced in the front of the engine? Is there a timing belt?
2 belts, and they require a 12mm and 14mm to change.
Tapatalkin'
I need to replace my belts soon.
Do belts give a little performance gain?
Yes! Without belts, your car has zero HP! j/k
I believe the engine will over heat way before the battery dies! (Coolant Pump)
