Spacer decision
Need some help guys. I use to run 20mm spacers in the rear and 15mm up front but took them off like a year ago and sold them cause I wasn't satisfied with the look.
I'm wanting to put spacers back on but I can't decide what I want. Dwayne has 30mm on the rear and 25mm up front on his FX50s and still the front sticks out a tad more than the rear. I don't want the tires to sit flush at all though I want them to poke out a little more past the wheel well. Flush isn't my style.
Even though Dwayne has 30MM in the rear I still think it doesn't poke as much as I would like. I was wondering if running 35mm in the rear and 25-30mm up front be okay? I'm trying my best so I can avoid running wider tires. I've seen the M sport X5/X6 and I like how the stock tires stretch out wayyyyyyyyy past the tire well.
---------- Post Merged at 06:42 PM ---------- Previous Post was at 06:40 PM ----------
One thing I hate about spacers though and it was like that before is that since the tires are brought out a little more it causes rock chips on the back doors because the tires kick up rocks more and fling them out. It basically makes the mudflaps useless.
Why didn't you like the 15/20 setup? I have 15 front and 25 rear and I love how they look. Basically flush to slight poke setup. I think going over 30mm in back is way to much poke doesn't look right IMO. Regarding the front I wouldn't go over 20mm, the fronts don't look good with poke, looks cleaner flushed.
Do something like this. Hella tight, yo.
