Ataher
- Tripoli - Libya
I have a 04' FX45, it has the VDC OFF and SLIP warning lights on, I have run a diagnostic with PC based scan tool and I got the U1000 error code which I tried to clear but no success, I have been searching all over and went through many cases, however I did not find a case quite like mine, the most famous case is that you may have a U1000 error but with no MIL, in those cases they suggest checking the grounding ... Etc, I have went through all grounding terminals, cleaned them and put them back again, but no change. Any advise will be appreciated. BTW I do not have check engine soon light on, everything else in the car is quite normal.Any help is really appreciated.
