Google it man. It has something to do with the transmission. You were having problems earlier with it not shifting properly or stuck in gear. Better take it to the dealer.
Has to do with the transmission, Possible Causes
OTHER TRANSMISSION DTC'S PRESENT
5 VOLT SUPPLY CIRCUIT OPEN
5 VOLT SUPPLY CIRCUIT OPEN INSIDE THE TRANSMISSION
TRANSMISSION OIL BURNT OR OIL PAN HAS EXCESSIVE DEBRIS - INTERNAL TRANSMISSION DAMAGE
GOVERNOR PRESSURE SENSOR
GOVERNOR PRESSURE SOLENOID
VALVE BODY
ENGINE CONTROL MODULE 5 VOLT SUPPLY
