money042
- Orange County, CA
- 2008 FX45
What? I've been reading that the Akebonos should bolt right up to the 09+ FX35 rotors..are you saying that's not correct?
Here what I found in my research. The Hub/Knuckle are the same, which means the caliper will bolt right on. But the rotors are different. The OEM 35 front rotor is 12.6", and the rotors paired for the Akebomo's are 14".
Front
40206-CL70A 2010 FX35 Base Right Rotor
40206-JL00A 2010 FX50 Base Right Rotor
40202-EJ70B 2010 FX35 Base Right Hub & bearing
40202-EJ70B 2010 FX50 Base Right Hub & bearing
