per4m28
Hi all, we finally got the Akebono BBK installation done this past weekend, here are a few pictures taken during the installation. Install was very straight forward and many Fx35 shared the same hardware for the akebono retrofit. Only thing that we did not have was and was not sure about was the banjo bolt sizing which I thought came in the hardware kit so we just cut it down 2-3mm shorter to fit the akebono's.
Here are the list of parts needed:
41011JL02A brakes, hydraulic system, front brakes, caliper assy FX50 Left (1)
41001JL02A brakes, hydraulic system, front brakes, caliper assy FX50 Right (1)
44011JL02A brakes, hydraulic system, rear brakes, caliper assy FX50 Left (1)
44001JL02A brakes, hydraulic system, rear brakes, caliper assy FX50 Right (1)
41217JL00A PIN (4)
44217JL00A PIN (4)
D1080JL00A Front Brake Hardware KIT (1)
D4080JL00A Rear Brake Hardware Kit (1)
41218JL00A CLIP (8) **Crazy how much infiniti asked for these little cotter keys Id suggest just getting these at home depot. lol
**The Correct length banjo bolt for akebono brake kit to adapt to stock brake lines. Not needed if going with stainless braided lines as they will come with them.
Choice of Front and Rear Rotors
Choice of Front and Rear Brake Pads
Stainless Steel Brake Lines Front and Rear (Optional) Stock FX35 lines will work.
Backing Plates Front & Rears (Optional)
41217JL00A PIN (4)
44217JL00A PIN (4)
