Good morning,
A friend of mine and I semi-installed BC coilovers and ran into problems. The front install went smoothly, but the problem appeared in the rear.
When attempting to remove the rear shock on both sides, the nut and bolt thread were so rusted, that after one attempt at loosening, everything I had squared off in yellow/red below were stripped and did not budge one bit after more attempts. Effectually, rust dust was left in the socket and the nut got smaller; 12mm to 11mm to 10mm and stopped trying.
Picture source: fxlr8's BC install DIY thread
Does anyone happen to know if the bolt that attaches to the rear shock mount in the wheel well is welded into the frame? Can it be replaced? Anyone have the rear interior removed to see what it looks like from the inside?
I just wanna know how to get that fixed if anyone can chime in...
Thank you, everyone!
(P.S. The previous owner lived in Minnesota. You would cringe if you saw my undercarriage. Treating it with POR-15 in the summer :smile (2)
