GTR wheels on a stock FX
Sorry for the thread bump. I assume this is stock GTR front and rear wheels right? I just got new ADV1 for my GTR and suddenly I find myself with an unused set of R35 wheels! I thought you have to run square but if not o might put them on my FX :)
No problem as long as you run tires of the same outside diameter , front and rear. The outside diameter should be the same as the FX OEM outside diameter or very close to that.
This is what you're looking at post coilovers.. I have a square set 20 x 10.5 gtr with 295/40r20 all around.. Post GTR, coilovers is a must!!
---------- Post added at 11:23 PM ---------- Previous post was at 11:21 PM ----------
I mean, it probably won't make enough difference but I don't see stretching that far being a good idea.
I wouldn't stretch it that much, the difference on the circumference could cause problems to the transfer case on the AWD
FX35 on Eibach springs with GTR Wheels.
I miss my old FX sometimes...
I have a rwd fx and i was wondering if the square set up with 295s would cause any problems. That sounds like a really fat tire on the steering wheels of a car. Im just wanting that flush look all around and i would be able to rotate tires
Drove mine a fair amount with no issues. I will say this though, i ran 295/40's to minimize sidewall mud effect when conering, ride was fine, cornering felt planted and being slightly smaller there was the gearing benefit :)
You'll be fine, it's not a big enough difference from 265 to 295 that your car isn't going to turn.
