2009 FX35/FX50 Rear Seat Center Armrest Release Lever Strap Fallen Off
ITB09044:
IF YOU CONFIRM: The rear seat center armrest release lever strap has come off (bolt has fallen out), ACTION 1. Inspect the strap, bolt, and spacer. 2. Reinstall the strap, strap bolt, and spacer. See this bulletin for further detail.
I can see the tech during the inspection....Hmm, can I confirm that the strap has fallen off...yep it fell off lol.
lmao
The funny thing is that this has happened to me too. I went to pull the armrest down in the back and the whole strap came off. I just put the bolt that holds it back on myself as I didn't see any reason to drive to Infiniti to put it back on when all they do is retorque the bolt to a tighter spec. A little bit of a pain in the ass because I had to remove the whole armrest to do it.
---------- Post added at 05:18 PM ---------- Previous post was at 05:16 PM ----------
By the way you'll know if your strap is about ready to come off if you wiggle it around and it feels loose. It should be really tight. Just a heads up....
