Wheel spacer and Coilovers question
Hello guys,
I'm looking into getting Coilovers and wheel spacers. For winter I'm running 04 stock rims on 265/60r18, and summer I have 22' on 285/35zr22. What size wheel spacer would work as I'm looking into getting Coilovers too as I'll be lowering the fx in summer time. From what I've read around Megan or bc Coilovers seem to be the top choice. Any other suggestions on Coilovers? Also for spacers brands and size?
Thank you.
Magan, BC or Kido coils. As far as spacers, is the offset of the summer rims the same as your stock winter wheels? If so 20 or 25mm spacers are the best. Latter if you want a more flush look, especially in the rear since they'll camber in a bit. As far as brand H&R or Ichiba spacers are what most memebers including myself run
Megan, BC or Kido coils. As far as spacers, is the offset of the summer rims the same as your stock winter wheels? If so 20 Front and 25mm Rear spacers are the best. Latter if you want a more flush look, especially in the rear since they'll camber in a bit. As far as brand H&R or Ichiba V2 spacers are what most memebers including myself run
IMO options on bold are your best friends.
