jayfx35
- Long Beach, NY
- 2003 Infiniti FX35
:top: Looks good, good job!!!
thats going to come off, sorry to break it too you, either way looks sexy!
Did you ever think of doing the 06+ shifter panel upgrade? Looks like your theme is to remove all the brighter metalwork in your car, but the panel looks great. My favorite part is the leather shift boot. Really worth the cost, effort to do and it really updates the interior drastically!
https://www.infinitiscene.com/search/1/?q=354-2006-Shifter-Panel-Upgrade
Like this look too loll and quick question let's say I only wanted to take off the circle shifter plate thing would that come off with a flat screwdriver by itself or would I have to remove the sides and then get to the circle plate?
looks pretty good I did my grille on my G37 and it came out amazing and has not had a problem in over a year.
pulling the steering wheel is easy in the fx, just remove the airbag from the center (2 bolts on the sides covered with tiny round plug) then loosen the center bolt of the steering wheel and just pull straight out hard, wiggle left then right as you pull but it will pop out with just pulling by hand, no steering wheel puller necissary. def put the center nut back on a little before you start pulling though because it does need a good amount of force to release... without that center nut in place loosely you might wind up knocking some teeth out when the wheel releases![]()
