Shocks for lowered 2nd gen fx?
RIPnFX
iS VIP
iS VIP
Infiniti FX 35 Limited Edition
Rip Singh
Hello I am new here and I have read many of your guys posts and they have been very helpful and informative. I recently bought a 2012 fx35 and just bought H&R springs. I just wanted to know if anyone swapped out the shocks and what kind they used? I am bit worried to lower the fx without changing the shocks. Will I be ok with the stock shocks? Any help will be greatly appreciated
Thanks for your reply PMG, by the your FX is bad ass. Also what size spacers do you recommend?
thanks..might be a good idea to look through the garages and see what spacer you want.. mlst go with a 20mm spacer all around; i think this gives you a flush fit up front and slight 5mm tuck out back..there are a few guys that have done the spacer route, but just can't think of them right now.
Ok great thanks for your help :)
---------- Post added at 04:24 PM ---------- Previous post was at 10:19 AM ----------
Also I read last years thread regarding the camber issue, is there any camber kit available yet?
PMg 705, what rims are those on your car? Size (height and width) and tires you are running?
I might need to get a second set of rims for the wife's car. A winter setup, and a summer setup.
Thanks!
Jon
Forgestar F14 22x9 et +30 with 265/40/22 Proxes ST II. Perfect flush up front, a slight tuck in back.. Offset 25 in back would make it flush all around.
