Fuel Hose Recall 03-04 FX
MTN FX
Mountain Man
Premium
Big Bear City,Ca.
2004 FX35 AWD
John Green
View attachment 249584ITB06-006b Safety Recall CampaignView attachment 249586
[TABLE="class: cms_table"]
[TR]
[TD]
2003-2004 INIFNITI G35 COUPE/SEDAN, 2003-2004 INFINITI FX35, 2003-2006 INFINITI FX45; VOLUNTARY RECALL CAMPAIGN FUEL HOSES
Infiniti has determined that some 2003–2004 model year Infiniti G35 sedan/coupe vehicles and 2003-2006 model year Infiniti FX35/45 vehicles may have a defect which relates to motor vehicle safety. There is the possibility that the fuel filler hose may crack and result in fuel leakage from the hose while refueling. If an ignition source is present, a fire could occur. In addition, fuel vapor hoses may crack and cause the malfunction indicator lamp to come on. To prevent this condition from occurring, Infiniti is conducting a Voluntary Safety Recall Campaign to replace the fuel filler and vapor hoses with new ones.
[/TD]
[/TR]
[/TABLE]
---------- Post added at 07:55 PM ---------- Previous post was at 07:47 PM ----------
Just saw this is listed under FX50 09 + could someone change this to 03-04 recall
Isn't this an old recall? I had this done on my '03 years ago.
Recall ID # 05V555000 - FUEL SYSTEM, GASOLINE
[TABLE="class: bg_recall_ovrCntr"]
[TR]
[TD="class: bg_recall_titlecell"]Recall Date:[/TD]
[TD]DEC 13, 2005[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell"]Component:[/TD]
[TD]FUEL SYSTEM, GASOLINE[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell"]Model Affected:[/TD]
[TD]FX35[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell"]Units Affected:[/TD]
[TD]192659[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell top"]Summary:[/TD]
[TD]ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING.[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell top"]Consequence:[/TD]
[TD]FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell top"]Remedy:[/TD]
[TD]DEALERS WILL REPLACE THE FUEL FILLER HOSE. RECALL BEGAN ON FEBRUARY 27, 2006, FOR NISSAN OWNERS, AND ON MARCH 13, 2006, FOR INFINITI OWNERS. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.[/TD]
[/TR]
[TR]
[TD="class: bg_recall_titlecell top"]Notes:[/TD]
[TD]NISSAN NORTH AMERICA, INC. R0505 & R0508[/TD]
[/TR]
[/TABLE]
Read more: http://www.automotive.com/2003/101/infiniti/fx35/base-sport-utility/349/recalls/#ixzz1iS5cgH6G
I smell it mostly on the rear pass side (not driver rear but other rear side) i smell it alot by the where you fill the gas up by and more by wheel well.
