Viperi's 2008 Fx35
So i turned them on at night and it was bright on one side and not the other :S. need 4 new bulbs(found random bulbs at home)! Also i had moisture build up inside. im hoping its from the silicone i used and isnt fully cured. will test tomorrow.
---------- Post Merged at 11:24 PM ---------- Previous Post was at 09:25 PM ----------
Nice job Andrew. Can you post some pic of front of the car with all lights off? I wanted to see how those AE off looks like. Those rings are very bright and solid. I'm still have some reservation on how yellow they're when they're not on!
crappy cellphone pics. i can get better if u want.
Wow your FX is really nice.
How are the spacers? any steering wheel shake or anything at speed or problems?
And the install on the sport tail lights what was involved? Is it a backyard thing for a newbie?
thanks. i got wheel shake between 1000-120km/hr. Nothing before or after. probally jsut got to tighten up the steering rack bolt. You do feel the fx more planted to the ground but turning gets stiffer. Installing the lights is very easy. Its just a few nuts and bolts and it pops out and unplug and plug new one in!
The steering getting stiffer is going to be a pain. I use my palm to drive and thats already difficult enough with this tight steering setup. But I guess even if I got more offset wheels it would have the same effect.
Let me know if and when you tighten the steering rack up if your wheel shake goes away. Because I drive this car 1200km at about those speeds monthly.
Good to hear about the lights. Thanks for the help.
102 000k. when i opened up my plenium i cleaned it all up but inside looked kinda nasty. couldn't believe the smoke coming out of it!
