Aluminum Pedal Set
Original Oreo
10 FX35 AWD
Just sharing information. While looking for some aluminum pedals to dress up my interior, I came across a number of options that ran up into the $100s for a complete set. I normally don't take chances with international purchases, but I rolled the dice with CarGym, a Chinese based company. The set listed for the 08+ EX fits the 2010 FX35 perfectly and, unlike some other sets I came across, includes the parking brake pedal for a complete 4 pedal set. The price is $58 for the whole set. CarGym does have a nice pic of the set on their website. In fairness, some time after my purchase I did come across a few negative comments about CarGym, but I personally found their communication to be very good and quick in response. I'm satisfied with the quality and appearance. I hope this information is helpful.
PMG - Yes and no. The dead pedal is directly screwed in; the supplied screws look like common stainless wood screws. The other three pedals have very small hex bolts with nuts that secure from the back side. You do have to drill through the pedal mounts which may be a little awkward depending upon the size of your drill. I found while fiddling around with the gas pedal that 1) I couldn't get a good angle with my drill and 2) I couldn't get my fingers all the way behind the pedal. I used my dremmel tool to drill a pilot hole into the gas pedal plastic a little smaller than the supplied bolts and then used the bolt like a screw securing it directly to the pedal. My rationale was I don't stomp on my gas so snug is fine vs. permanently affixed. If someone is concerned about being secure, you can always use epoxy in addition to the bolts and loctite on the nuts. I hope this is helpful.
