H & R Sport Springs
315fx35
Syracuse NY
Set of these for sale used near me in NY for dirt cheap. I will be putting an intake, exhaust on and would like a stiffer ride with less body roll. Anyone used these? Review? Thanks
H&R Part Number 53043
Drop Rate: 1.3"F, 1.2"R
-Pete
You will get a softer ride. Not so much stiffer.
You can cut the springs for a lower drop and the ride would be stiffer.
You can also get Eibach lowering springs and they ride stiff out the box.
If they're the ones in a city starting with a w (don't remember the name) I already have them.... :wub:
Search bar is your freind----
Search Results
///14349
Search Results
H & R Sport springs
G35 or G37 springs
Free: Stock fx35 RWD springs
FS: H&R Lowering springs
FS: 1G H&R Sport Lowering springs for FX3…
Lowering springs
FS: Eibach Lowering springs + KYB shocks and …
spring Cleaning!
H&R springs now available from allsprings…
Tein lowering springs?
spring Tour and Track Day-May 28th GTAFX
spring 2011 GTG For Edmonton and area.
spring 2011 Chicago Area Meet
Eibach spring Install on 09 FX35 AWD
H&R or Eibach springs/Why?
H&R springs, Struts and Shocks and/or Spa…
Coilover spring rates Suggestions
Tri State FXers! spring Break MEET /five boro…
Timing internal Issues when using different V…
Eibach springs Group Pre-Order
Place to install springs
Is this the reason you are changing the spri…
Will this Tire, spring and Spacer Combination…
sprint Booster
My Labor Day Weekend Project: H&R 20mm s…
drop springs cut???
Shocks / springs Dilemma
Worth keeping OEM springs?
09+ H&R springs !!
Shop to install springs
GTSPEC Lowering spring *** Gathering Info ***
about h&r sport dropsprings
springs? Struts? Shocks? Whats wrong?
lowering springs
sprint Karting anyone?
H&R springs
spring clamps
2009 FX35,Lowering springs/Preferred Drop Sho…
H&R spring and KYB Shock "Settling&q…
springs cut
springs & spacers
anyone installed H&R springs on 09+ FX ye…
New Wheels and Lowering springs
Does lowering springs help at all?
Install New Shocks,Struts and H&R springs
springs for the 09 model
KYB with stock springs
struts and springs
H&R lower spring....
Looking to drop, which set of springs?
can i cut stock springs?
new springs
H&R springs question
H&R springs: Review
spring Drop Pics
springy sound, E-brake cable?
spring Install in Texas
Cut/Shave spring and Mount
Cutting springs
correct springs??
Cut the wrong spring!!!!
2009 FX35 FX50 springs (Info)
Purchasing springs
275/45/20 To cut or not to cut springs???
any pics of cut h&r springs?
spring/Summer
spring cleaning - post your freshly cleaned r…
2009 spring meet...GET IN HERE, I KNOW THERES…
springs? Shocks? Suspension?
cutting front springs????
Another Blown Eibach spring
09 spring rate
$450 to install springs and catback - fair pr…
H&R springs for FX50 and 09 FX35
H&R springs for the EX35
Off to palm springs
spring Compressor Recommendations
spring Install
Eibach springs on 18s
intrax springs
Lowering springs for an 08' EX35
Deal on H&R springs
lexus gs350 springs
sprint!!!!
Front Eibach springs May be missing
H&R springs
spring/Summer mod list...lets hear it
spring install
Cutting aftermarket springs
H&R springs/Spacers
Ordered springs and 275/45/20 tires
New Blisten Shocks and springs for FX?
anyone with FX45 have H&R springs?
Lowering springs
Infiniti FX Lowering springs
How long will it take for spring to settle?
H&R's will smooth it out a little while Eibachs add a little stiffness. Coilovers are adjustable either way.
I have H&R's on mine and im really satisfied with them!:tup::tup: ... i assumed they would stiffen up the ride but it actually really did help improve the ride quality ... cornering is better ... and from what i have heard, the braking improves as well:wub:
