Front Interior Dome Lights wont shut off?
pmanliu
iS VIP
iS VIP
NYC
2017 WRX
Long story short -
was messing around and swapping LEDs into the front 2 dome lights. Now they wont shut off.. ever. The rest of the dome lights are behaving normally
Pressing down on the plastic cover wont shut the lights off (doors closed & open)
Toggling the Door -> Off switch does nothing.
Everything (engine, lights, etc) off, shut doors, lock cars, they remain on.
Had to pull out the bulbs for the time being.
I'm pretty clueless on this one... any suggestions?:eek.:
Possibly the fuse or sounds like one of the door jam switches went bad theres a little push switch on the jam between the door and th body that's most likely stuck on the on position disconnect one at a time until the light goes out the one you disconnect when the light goes out is the bad one
I have a question about my interior lights not staying on. I just changed to the LED kit that a member on here sold me and I installed all of them and once the key is out of the ignition, all the interior lights go off and I cant even turn on the dome lights. Has anyone had this issue??
The ignition should not have an effect on the dome lights. They should react the same as before. With LED's, most of the aftermarket bulbs have less resistance than OEM bulbs. So they can act a little funny like they won't dim properly. I have an LCD drop down monitor in place of the dome light, it has LED lights as the dome light. When I swapped the other bulbs over, things got a little weird. If my dome light is on, my front map lights are on at half power.
But I'm not sure why none of them would turn on. They should all be live even with the ignition off.
