Steering wheel shake problem
kidfx35
Chicago, IL
2004 FX35 AWD
wassup chi-town need help
Good Morning,
anyone from chi-town be able to help me adjust that steering wheel shake problem? Adjusting the steering rack 24mm bolt was seeing if someone that has already done it can do mine, please me know if you can be of assistance i can compensate you for your services, thank you.
https://www.infinitiscene.com/search/1/?q=s...ad.php?t=11604
Just FYI... on a stock height FX with the wheels turned all the way to the right you can reach it without jacking up the vehicle. Just reach in with a half-inch ratchet & 24mm socket and give it a 1/8 turn. That's how I do it anyway.
I plan to do this little adjustment on the steering wheel bolt this weekend, possibly Friday late afternoon. I don't mind to give you a hand at that while I'm doing mine. Just to warn you I have not done this before though and I'm in Aurora if you come out :eek.:
I found it impossible with H&R's, aftermarket wheels and GTSpec bars, unless I removed the wheel.
I also turned mine about a full turn and it's been over a year with no issues. I did FX45CHICAGO 1/4 of a turn.
the pics i posted are just to show where the bolt is, taking the wheel out is not necessary. my FX is at stock height and i just went underneath and tightened it a little at a time. it's easy. just turn a little, drive and see if that's enough, if not, turn more, repeat. different cars need different amount of turns. don't just go give it two full turns. :wink (2):
wassup la fx how did it turn out?
