So there are a lot of threads on what spacer will fit OEM wheels, but what about any wheel that has a flat face for 100% clearance of studs?
Jeff's post was very helpful:
///13930
To find out that OEM studs are 30 mm long.
Now, take into account the thickness of the rotor and where the stud mounts to, adds up to XX mm.
So, on a flat face wheel, the clearance should be 30mm -- XX mm = YY mm.
My best guess is a 25 mm spacer is the minimum size to clear any wheel, whether it has dimples/holes in between. If it has dimples/holes in between, it would be reduced, e.g. 20 mm spacer.
Any ideas here?
///13930
Any ideas here?
