myl168
- Dallas, Tx
- 2003 fx45
Hi Guys,
I just rolled passed 90K on the odometer. I plan on starting some maintenance on my 45 this weekend. There are not as many write ups for the 45 and had a few questions.
The only things I'm unsure about and haven't seen a write ups on are changing the spark plugs, and changing the belts.
Spark Plugs: Should I get the NGK platinum PLFR6A-11 "cold" plugs? Are these pre-gapped? Anyone have any tips or photos to help?
Belts: There are 2. drive belt and a power steering belt. change both, does anyone know the part numbers? I saw some on eBay, but was unsure. Do i need to replace the belt tensioners? Again, anyone have tips or photos? Should I replace the water pump?
I was planning on flushing the coolant around 120K. should I replace the hoses and thermostat?
Other stuff I plan on doing.
Oil Change
Tranny Drain and Fill
Front and Rear Diff Drain and Fill
Installing sport headlights
Any other ideas or anything you would suggest would help. I'd like to do as much as possible by myself, but might consider taking it somewhere if you guys think some task are to difficult.
Thanks in advance.
Oil Change
Thanks in advance.
