installed 20mm rear spacers (pics)
[Did you shave your fenders? That's what it looks like to me. I rolled my fenders, seems less evasive. ]
yes i did shave them, I took them down as far as i could. I was going to roll them but i needed as much possible room to fit the 10.5 wide wheels with 20mills,lol It looked alot better after I touched it up with some black primer ill order some color matched touch up paint to make it look even better. I did take the medal down and smoothed it with a dull 240 grit which made it VERY smooth to the touchwhen You slide your fingers across it.
[Looking good do you have spacers in the front too? ]
Not yet I need to do some minor adjustments to the camber I might go for a -1.5 or -2 to get the stance look I need then ill roll the fender and take out the liner cut the tabs then ill do my measurements im guessing it will be around a 10mm to flush it out
looks great! I will be doing the same when i get my fx, i saved my H&R 15 and 20mm spacers and studs after returning my Z back to stock.
looks good, any pictures from side view? Did I see your FX in a Spirit parking lot along Oliver last week? (maybe 2 weeks ago)
Yep sure did that's were I work. It's nice to know another fx member lives in the flat plains do you live in wichita?
---------- Post added at 05:53 PM ---------- Previous post was at 05:52 PM ----------
Depending on what size and offset of wheels you get those sizes would be perfect
I live in Wellington, but I work at Spirit. While comming back from lunch the other day, I spotted your killer looking FX. Love those wheels.
