T
TyroFX
Guest
Alright so I went to start up my FX this morning and it had absolutely no power. Lights, alarm, horn, nothing. I haven't started it for about 2 weeks and left it in the garage. Help?
Battery probably died...did you try jumping it??
Yes I did and it was successful. The problem is a couple days later it will die again with absolutely no power. Is it a weak battery issue or..? I'm thinking about switching to an optima.
Just curious, when u jump start do u always have to put the black plug to the ground on the dead car?
Ive usually have done it that way to many older cars but one guy didnt put the black to the ground he just connected it to his dead battery. He had a beamer and there wasnt alot of visible metal to connect to and he wasnt sure so he just connected it to the battery.
Is it the original battery? If so, you might need a new one. I just put in a new red optima last month as my car gave me trouble starting up once in awhile and now that is gone...my car doesn't just start up...it jumps up. Looks like the alternator is probably charging it when running but then it's not holding the charge...get the optima or the bosch is good also and way cheaper.
It's not the original battery. It was actually replaced about a month and a half ago. I probably will end up buying the optima yellow top.
Well If you replaced the battery recently then it might be the alternator...it shouldnt be dying out if it's new. I would have your alternator checked out also.
When you jumped it, how long did it run?
Sent from my BlackBerry 9800
