Thanks for all the feedback, comments and voting so far.
Here is what I'm leaning towards now. It looks like it should work using the calculator, but, can anyone take me to 100% it will work? :smile (2):
Option 6: the Aggressive Rookie, Deep Concave all around, maximum width in rear
22x10.5 Front +30mm offset on 305/35/22 tire (30.40 inch tire diameter, 42mm more than stock offset)
22x12 Rear +49mm offset on 305/35/22 tire (30.40 inch tire diameter, 42mm more than stock offset)
I am 90% sure the front fitment works (pushes even closer to strut).
I am 90% sure the rear fitment works (pushes closer in the fender).
I am more confident in this setup because it pushes it so far out, inner clearance for any suspension should be fine. But the 10% is again the fender rub.
