buying some spacers today 38mm/15mm
infinitifan25
wichita
all of you know I need spacers BAD! well today when I get home im ordering some. since i am dropped to the max have a negative camber my rear wheels stick in a little more than 2'' from flush with the outside trim. 38mm will take care of that. the frontis not to bad so im going with 15 mm maybe 10mm ill do another measurement today. ill have to trim the rear wheel wells and maybe bring it up about a 1/4' front and back to make a bit more room so wish me luck and ill post pictures when done. now to try to find the best deal?
Wow 38 mm spacer in the rear? You definitely will need to trim the black wheel well molding and roll the fender. Google for a "fender roller rental" and find one you want to rent from. Here is one, http://www.rollyourfender.com/. This tool works great. I rented one and work out well. You just need to trim and roll enough top of the wheel arch so you can still screw the molding back on. Good luck!
Are you on stock OEM 20's? If so you need at minimum 20mm spacers for non-extended studs.
Go 25mm all around in my suggestion. And yes, use Charles at B2Auto, he has a thread here on spacers. Go either Ichiban (spelling??), H&R's or Eibach's.
thanks for letting me know about b2 i will call them for sure. i will be rolling on stock 20's in the winter time but right now i have 22x10.5 with a 43 offset ill post a picture below to show just how far in it is. kind of embarrasing to me :embarrassed:
That is tucked. Kind of like when Humberto had Axis Titan's without spacers=)
Lip looks awesome though. 38 is pretty aggressive, 25 is a little tucked from the looks of it, around 30 might be perfect but not sure if that is available.
just ordered the v1 15mm for the front and the v2 30mm for the rear. i would have to lift the car to much and do to much cutting for the 38mm and thats the opposite look of what im trying to achieve,lol thanks guys for the input :tup:
