F XXX :: 2004 Infiniti FX35
Nice tails, looking choice! Ever think of Alumiweld to fix that brace? DIY = much cheaper. Saw some vids on YouTube, doesn't look too difficult and the bond strength is very strong. Gonna give those rods a try on a lil project I have going soon.
How are the 10.5 wide tires? Are there any issues with them rubbing, touching etc... And you only use your spacers for your winters right?
Sounds interesting, ill have to check that out
The tires will rub a little in the back with 4 people in it, most of the its fine unless you hit a big dip.
I run 20mm h&r spacers
Jef normally runs with 3-4 thin built large breasted naked women in his ride (his wifey is coolio) the weight is lower than the normal adult weight average, you'll need to take this into consideration.
^ this is true, I should have mentioned that :wink:
---------- Post added at 05:57 PM ---------- Previous post was at 07:04 AM ----------
I also have 295 tires on them 285 might not rub at all
So the 10.5 inch has nothing to do with the rubbing just the face that your sidewall in a bit larger. Cause I love the look of the beefy 10.5 inch wide tires. Just wanted to know if it touched any suspension parts or any mods were necessary to accommodate the wider 10.5 inch tires.
10.5 is the wheel width, there is plenty of room for that wide of a wheel as long as you get the right offset mine is +30.
295 is width of the tires I run.
I actually have 5mm spacers in the rear because my wheel center caps wouldnt fit on without them. So take away the spacers and for sure it would not rub.
The rubbing I get is tire to fender nothing suspension wise I think I might camber my wheels in more to fix my issues
---------- Post added at 08:00 PM ---------- Previous post was at 07:52 PM ----------
I had my fenders rolled and cut the plastic trim around the wheels
Late night last night but everything is wired up for the Euro tails. My friend wired it so I now have 2 pigtails for lights so I can easily switch from the Euro to stock tails anytime I wish. The stock tails are in right now and my bodyshop has the lights for a little paint work. They are getting the outer edges painted body color...Cant wait to get them back
