infinitifan25
- wichita
YOU WILL NEED TO REMOVE THE REAR HATCH PANEL FROM THE INSIDE
YOU WILL NEED THESE ITEMS
RATCHET
6"+ EXTENSION
5/16 SOCKET
FLATHEAD "THE LARGER THE HEAD THE BETTER"
GOO GONE
HAIR DRYER OR HEAT GUN
1. UPPER TRIM PIECES. THERE WILL BE "4" 5/16 NUTS TO TAKE OFF MAKE SURE AFTER YOU TAKE OUT ALL "4" TO HEAT THE TRIM UP BEFORE REMOVING IT. YOU CAN REMOVE THE BLACK BOX TO GAIN ACCESS TO THE RIGHT HAND NUT BY EASILY USING A PHILLIPS OR 10MM SOCKET. THERE WILL ALSO BE TWO RED PUSH CLIPS BETWEEN THE OUTSIDE 10MM NUTS TAKE CAUTION PRYING THOSE OFF.
2. THE LOWER TRIM WILL HAVE "1" 5/16 NUT ON EACH FAR END SIDE WITH "2" RED CLIPS ON THE INSIDE OF THE TRIM RED CIRCLES ARE THE 5/16 NUTS & YELLOW CIRCLES ARE THE CLIPS. DONT WORRY ABOUT THE PUSH CLIPS TILL YOU LIFT THE TWO EDGES OF THE TRIM UP. USE THE FLAT HEAD SCREWDRIVER AND PLACE IT AS CLOSE AS YOU CAN TO THE CLIP FROM THE OUTSIDE AND TWIST IT USING THE FORSE FROM THE TRIM AND THE HATCH TO BREAK THE CLIP LOOSE. THIS WILL KEEP YOUR TRIM FROM DAMAGING AND YOUR CLIP FROM BREAKING.
3. THIS IS FOR THE UPPER INFINITI LOG ABOVE THE UPPER TRIM. HEAT THE LOGO TO WERE ITS HOT TO THE TOUCH THEN USE THE END OF THE RATCHET OR AN EXTENSION TO EVENLY PUSH OUT THE PINS
RATCHET
6"+ EXTENSION
5/16 SOCKET
GOO GONE
