- 2004 FX35 AWD
- Name
- John Green
They seem more visible to me especially from a wider angle.I feel like the video isn't a good judge, so in person does the turn signal still stand out well against the other lights?
Oh bubble mailers. Wouldn't be surprised at all if USPS was messing them up.
Maybe we could ask TC6 to make us some water cooling systems, haha!I hope thats the case but I worry that the issue may be that these bulbs run so hot.
Neither of mine will light up, and I did the little move the wire rig. Pretty sure my pins are going to snap at some point, as they get bent up when removing the bulb.
Can we just return the non-fitting bulbs for some that should be plug n play?
No, I think it's on from when I was testing the reverse lights. Does that affect something?Was your parking brake off?
Yup the DTRL turn off when parking brake is appliedNo, I think it's on from when I was testing the reverse lights. Does that affect something?
Linky no worky.
I have a feeling that the issue is they just run too hot.OH NOOI put mine in the original DTRL slot and one (for sure) started to flicker (I was driving and saw it on the reflection from the car in front of me while stopped at a light so didn't get a chance to see if both were flickering). It wasn't a rapid on/off but rather a slow one. This started to occur after about 20 minutes of driving with DTRL & low beam on. So I turned them off and drove for 2 hrs. Now I turned them back on to take videos and they're not flickering. I'm running them for a while to see if it'll start to flicker.
Let us know if the problem comes back after heating up. I have a feeling that they just run too hot.
Don't worry guys, this GB is backed with warranty. I just think it could be damaged from the USPS delivery. I'm switching over to boxes as opposed of bubble mailers. Will get in contact for a replacement soon.
If there was a problem, both should be flickering. But I only hope it was damaged during transit. Thank you.
Sent from iPhone.
