It would only void the warranty on anything that is affected by your suspension.Im thinking yes? or am i wrong
Would this also apply to the H & R's. I just ordered mine for my 2009 FX35. How does it affect the alignment?It would only void the warranty on anything that is affected by your suspension.
I would not be in a rush to do it until someone starts to produce camber arms or something to correct the alignment after you lower it.
I had to take my lowering springs off because of this.
As to the alignment the H&Rs will affect it more than the Eibachs since it is a greater drop. You will need something to correct it if you are concerned about tire wear. But , it will look sweet.Would this also apply to the H & R's. I just ordered mine for my 2009 FX35. How does it affect the alignment?
Like Jesse said, if you don't put a lot of miles on then put them on. I loved mine for both the looks and handling, but I would have to replace my tires in two months on my summer trips :eek.:, so I had to take mine off.Hm, i guess ill wait on cambers then.
