New tires seemingly cause pulling left and right
98DOHC
FL
I just replaced the rear tires (which were stock Potenza RE92A's), with Hankook Ventus AS RH07's. The pulling becomes most noticeable around 70 MPH. If i'm cruising on a strait level road with no crosswind and i let off the gas. The car will start to drift/pull to the right. If i get back on the gas to maintain speed the car starts to drift/pull back to the left. IIRC, when getting back on the gas im applying enough throttle to regain the 1-2 MPH i lost while letting the car coast.
Now when i say drift/pull. This action seemingly comes from the rear end of the car only. I dont feel any input through the steering wheel. The amount of pull at 70 is enough that if i dont correct the direction of the car, it would take about 2 seconds or less for me to start crossing the line into the next lane. My starting position would be the center of my lane. This can also be done starting at around 45 MPH in 3rd gear. 3rd gear is needed to create enough load either accelerating or decelerating. At least 50% throttle is required also. The departure angle is much less at this speed though. It would take a good 4+ seconds to reach the next lane.
I did not notice the behavior at all before the new tires where put on. I noticed with about 15 miles on the tires as that is when i first hit the highway. It has done it consistently since then in numerous road conditions. And is repeatable with every attempt.
So far i have had the alignment checked. Result. Back is within spec. Front, Toe: Left is -0.07 Right is +0.10 Everything else is within spec. So my toe is slightly off. But at those numbers the tires should be nearly perfectly strait in relation to each other. Slamming on the brakes at 70 MPH with no hands, the car tracks strait as could be. And tracks strait in every other situation and does not pull.
Tires pressure is spot on.
Tires are both RH07's and the correct size.(seen someone else have a very similar issue and this was one cause, alone with a separate case where the tire pressure was way off(80 psi))
I still have two stock tires on the car(front). The tread is just about gone. But they are fine for dry pavement. I swapped the front and rears. So now i have the stock tires on the rear. I did a short highway drive (70 MPH test) and my 45 MPH test on surface streets. The car no longer drift/pulls. I will verify the pulling is gone tomorrow when i do a longer drive on the highway.
Another thing i noticed about both tires. The New Hankooks. When in the rear they make the rear end lunge into hard turns. But this is a delayed action and it's a bit unpredictable. With the wrong person behind the wheel i could see a aggressive lane switch on the highway coming close to a accident. When the Hankooks are on the front, the initial turn-in is reduced. IE, i have to turn the wheel much more to get the car to change direction. But the previously mentioned behavior when they are on the rear does not carry over to the front. And with the stocks on the rear, the rear acts tight, follows everything you command and is predictable.
At first i was thinking i had some bad bushings or the alignment was off in the rear and/or the new tread/tread design was just grabbing the road better and bring out a existing issue. But now i'm leaning towards the idea that these new tires may just suck and i need to get something different.
Sorry for the long post. But i've asked around quiet a bit. And the tire shop/everyone i've asked is at a loss. My next step may be the dealer, but im avoiding that.
Any ideas or opinions as to whats going on?
It is better to replace all 4 tires at once. if tires worn unevenly,then it will pull you side to side. I am not saying obnormal wear,but if front 4/32 for example and rear 10/32 then ride will suffer and you won't go 100% straight.
Make sure alignment is correct.
I dont see how a tread depth difference front to back would cause this issue. Left to right i would understand.
But too clear that up as a likely issue. Before i replaced the rears(they were identical stock tires. And the same age as the fronts). The left rear nearly had the belt showing in the center. And the right rear was probably around 1/32 or 2/32. When the tires where like this i did not experience pull/drift im getting with the new tires now. Also as mentioned in my OP i swapped the tires and this seems to clear up the issue.
interesting.. have you tired swapping LEFT >, < RIGHT and retest if it pulls opposite?
Hankook Ventus AS RH07 are bi-directional design.
So no issues being in the front? if not, replace the 2 Bridgestones with Yoko's =)
I have not tried that swap. Good idea. Ill give that a try tonight.
Correct, no "issue". But sub par handling though. That is in comparison with the stock tires.
If it comes down to it, i will burn these things up. And replace all 4. Im already looking at getting replacements for these two though now. I was looking at either Kumho Ecsta STX KL12 or Falken Ziex S/TZ-01's What Yoko's are you referring to?
I would look at reviews for those tires, I know I had a set of tires once and it did the same thing. In the end, the tires were a bad design that would cause drift one direction or the other. The alignment shop couldn't do anything because the tread design would create a pull if certain minute conditions were occuring at the time. Also because our vehicle has wide tires, this becomes that much more noticeable for a tire that's not designed as such.
Not stating this is the case but its worth a thought. Can you get the tires exchanged under warranty? Maybe there's a defect or recall on those tires?
lots of members have great feedback from using Yokohama Parada's Spec X, they are also very competitive in pricing, ~ 155 each.
http://www.tirerack.com/tires/tires...dewall=Blackwall&partnum=65VR0PSXXL&tab=Sizes
manufacturer site: http://www.yokohamatire.com/tires/parada_specx.aspx
Unfortunately i dont have the sport package/20inch wheels. So those wont work. Thanks though.
This is what i've been suspecting. Nice to finally see someone else has had a similar issue. I'm going to try the swap soonster mentioned and if the issue is still the same i will be contacting the tire shop and see if they can help me out. I may try contacting Hankook also.
Sorry for stupid question,but make sure air pressure is right everywhere before you do any other steps.
Sometimes tire shop overinflate one tire and you can't spot it with your eye,but it will pull you to the side. :smug:
Yes that was something that was already checked. As mentioned in my original post. On my end the pressure was checked by TPMS and a hand held gauge that is know to be accurate.
So i swapped the tires back to the rear and on opposite sides. The car now pulls to the left under acceleration and to the right on deceleration(Opposite of before). So while this seems to prove the tire are the cause. Im not sure if its both tires or maybe just one. Either way im going to try and get different tires(Another brand) from either the shop or i will have to buy new ones. In which case, the problematic ones will be used for a smoke show or some other tire destructive fun.:smug:
Thanks for all the replies everyone!
