When I look closely behind the headlight, the space at the corners where the turn signal bulbs are located seems tight. I was able to change the DTRL bulbs easily of course since there is plenty of room to reach back there and remove those...
Did you guys contort your arm to get it back in that corner space to change the bulbs or is there a "trick" to removing them easier?
Thanks.
Thanks.
