GT-R Ignition Button
just put in the order :D, had to pull the trigger if GTO says so :D
imma have glendale infiniti install it ill take some pix while doing it. I hope it fits well other wise waist of time
Coming from doing this on my G. It is an easy install. I actually took the guts out of it too so I still had the same light up color. It fits 100% OEM. Hardest part of the install is getting the retainer pushed so you can unplug the connector.
---------- Post added at 05:31 PM ---------- Previous post was at 05:27 PM ----------
http://www.the370z.com/diy-section-do-yourself/18606-diy-gtr-red-start-stop-button-swap-out.html
Here is a link to the swap out on a Z. I did this to my G and it is super easy. Go the little bit extra and change the gutas out so you still light up with the stock infiniti colors and not the yellow GTR color.
