So after the dyno tune and seeing the (little) amount of power that was added (without tuning ignition timing at all btw…5hp, 9tq) I've decided to get either resonated test pipes or high flow catalytic converters, and will most likely add an X pipe to the exhaust (RTP and HFC will raise the volume, and may add rasp - X pipe will take car of rasp)
TP/RTP/HFC from the 3.7 models should fit fine (besides the motor dyne ART pipes since the resonator on those will not fit on AWD models)
I'm doing so for the power gains, and to get a little more sound because although I like how it sounds now, it is still a bit "too" quiet after I thought it would have broken in more.
I've been trying to find a set of Used Resonated Test Pipes on the g/x forums but have also contacted Gordon for Invidia HFC/TP pricing.
Looking at a set of GTM resonated test pipes, found a barely used set for a decent price. I wish Invidia made RTP because I would rather buy new and from a fellow member but we shall see.
Stay tuned.
edit: Purchased a set of used GTM RTP with ~100 miles on them, essentially brand new. 30% MSRP. (not too bad)
They come with the needed extended Jpipe for o2 sensors, bungs for wideband, and are 'quieter' than standard test pipes due to resonating chambers.
Should be to my house before I am, but they'll be on in about two weeks. If they're too loud, I'll just sell them to thenext guy in like from the thread I bought them on, and go HFC.
