Torn on wheels, need advice
im just a bit skeptical on the step lip. With a regular lip, 20s already look much smaller.. with a step lip... its going to be even more so
I'm also thinking about picking up a set of 521-- 20 x 10.5 +30 all around, my car is all wheel drive so I have no choice. how will the fitment be? is anyone running these specs? Would be nice to see how the fitment would be. My only worry is that the the front will stick out more than the back... Any advice would be appreciated
You'll be fine with that setup. When I took my wheels off I moved the spacer to the front to have a look, it was 20x10.5 and an ET 28mm, it looked ok. I didn't drive on it though but I forsee no problems with that setup.
I would go with the second if you can get it in all black... as far as an offset depends on how far you want the wheels to stick out... you can use any of the wheel/tire calculators to decide what you want..
