GUESS WHAT GUYS??
I fixed the fog light!
and I used the splash guard removal method! Too easy! It took me almost 30 minutes.. I think I rushed because I had to get to work lol sorry it took too long for me to post it- I'm just excited now.
Thanks guys for all your help.
If any person is wondering, the only tools I used were a screw driver, a flat head screw (to remove clips), and a small screw driver to remove the fog light housing since the reservoir is in the way.
In all honesty, the whole task would've been A LOT easier if I had removed the wheel, I just didn't remove the wheel because I didn't have a torque wrench and I know you have to set it to 80 lbs/ft. although my setting is 85.
Anyway, there are three clips to remove, two screws to remove on the outside, and about four on the bottom of the car. Once you're done with that, remove the splash guard then you can stick your head under there.
*BTW: I used two jack stands to lift the car.. I'm not sure if that's safe. They're both new Craftsman jacks.*
To remove the housing, just twist the bulb out of the housing, then there will be a screw at the 1 o'clock position, it's a pretty long screw. Once removed, there is a clip that you pull down (at the 6 o' clock position). It was hard for me, so I used a flat head screw, then I PUSHED THE HOUSING
OUT.
I, then, got my new housing + bulb and did everything backwards.. except the bulb was already in there, so I didn't need to wait to put it in.
The toughest part of the job were the three clips.. because they sometimes cracked which made me angry lol oh and the fact that the tire was in the way so I had to really stick my head in there to see the housing. (that's what she said.)
So basically, you don't actually need to remove the bumper.. saved me a lot of time.
Thanks again, guys!
---------- Post added at 07:15 PM ---------- Previous post was at 07:06 PM ----------
Fixed fog lights. :]
---------- Post added at 07:16 PM ---------- Previous post was at 07:15 PM ----------
By the way, you guys should check out CupCake Meet. If y'all haven't already?
*Mainly aiming to the people who live in Houston, AUSTIN, or Dallas, TX*
I would like to see more FX35s come to the meets. The president is cute if y'all were wondering.
http://www.ccmeets.com/
Thanks, guys! Sorry again for the month late reply
