I was comparing to some aftermarket wheel like OZ ultralegeggaras or my Enkei GTC 01 wheels. I know my Enkeis which are 8.5/20 weigh 24 lbs. There are lighter wheels than that out there.I don't think it is heavier than the stock 09 20's...and definitely lighter than my 22's...
:If weight doesn't matter to you (I thought it did because you mentioned weight in your post) then I agree with your choice and the reasons. Those wheels would look great on your ride.I know that there are aftermarket wheels lighter than this, like Enkei or OZ but they have one big advantage over those two manufacturers wich is the price. I can get this set at half of the cost of those two and i don't think the weight difference matters so much.
I have aleays loved the look of your present 22s, I think they really go well with your FX.
I didn't recommend 285/45/20 because your tire choices are very limited in that size. If you are happy with the tire selection then that would be a good choice.I really want a 45 sidewall so 275/50R20 or 265/50R20 are out of the question. I think i can put 285/45R20 to be almost the same height. I think 295 are too wide for a 9,5 rim.
Why you wouldnt recomend me those tire sizes? The 22's has a 285/35R22 tires and the difference between those and a 275/45R20 in circumference is 0.2 inches. Do you think the gap is too big even when i will lower it?
