Break,slip, vdc off lights on*
Adam.
Houston
2006 Infiniti FX35
So all of those lights are ON right now on my cluster,
car works fine. runs fine. gears shift fine.
i left work around 7pm to come home...
when i turned the car ON, they turned off and after 10-15seconds they went on and havent turned off??
anyone had this issue before ? if so, what should i do ?
please help.
thanks.
Check your brake fluid level, if it is low, it is probably due to worn brakes. If there is still lots of wear left and the fluid is a bit low, top it up to the correct level. This has happened to me.
Slip vdc can mean alot of things.did you get new rims if so get a wheel allignment it will probably come off.also make sure u don't have the e brake pushed down.
nop. im on stock wheels, im about to check the fluid hope thats where the issue is.
Happened on mine also. Brake light came on for about 5 seconds shut off then the VDC off light came on along with the traction control light and stayed on until I shut the car off. Ended up being low brake fluid. Dealer checked that and all brake pads. Good to go!
Sent from my ADR6300
What if it's only the slip and VDC lights that are on? I get them randomly whenever I turn on the car and it doesn't go away until I turn the car off. Didn't really think too much about it since it seems so random and shrugged it off as a computer issue. Guess I should check my brake fluid also
