Some photos of my ride
Rear bumper lights, how i've installed them:
First of all i removed the stock
then made a hole for the wire and screwed them
unfortunately I forgot the name of this box. It is responsible for lights, rather a stop signal and marker lights. You must connect to wires that come to her, that is before, not after. Otherwise lights will not work.
Also under this box shows the hole through which I stretched the wire, as if I removed the wire from the tow bar and instead paved the wires from the bumper lights
That connector that connects to the wire.do not pay attention to the color of the wires connected to the connector , because the wires from the lights is shorter and they had to be lengthened
That connector is already connected and wires are connected to it
Sorry for the quality, photos are made by my iphone 3g.
the last photo is blurred.
And night photos:
As stop signal
I made the picture of subwoofer (stealth)
Also i have installed HKS magnetizer
I do not feel the difference. A couple of weeks will drive with it and remove it. After it will put on my friends ride (Kia SEED) and see if he will feel the difference
from hks: "
10 - 25% on average fuel savings - depending on age of engine
5 - 15% increase in horse power - high octane performance with lower octane fuel
50 - 95% reduction of Carbon Monoxide and Hydrocarbons
83% average reduction of hydrocarbons
Engine runs cleaner and therefore oil lasts longer
Improved performance - quicker starts and faster running
Maintains cooling system efficiency
Stops scale build up and corrosion in your engine
Reduces wear on oxygen sensor and Catalytic Converter
Healthier air and less smog for your community
Suitable for gasoline, diesel, cars and light trucks"
I doubt it really does much....most likely a gimmick
I'e recieved black knobs, and have already installed them.
One good man drew to me my car on paper
Thank you. it's not the first his picture=)
here another works:
He draws by pencil
I also make some Plasti dip
before
after
I like how you're always working on your car George.. this time, I like the way you had it before. IMO the texture of the plasti dip contrasts too much with the rest of the car.
PMG_705, it was the reason why i desided to Plasti Dip grill and miror covers. I will do in some time cilias and chrome (chrome on the back door, door handle, lower chrome on doors and railings) They are under matte black vinil, which must be upgraded.
