BMW wheels
sirtrojan
Poland, Warsaw
2006 FX35 AWD
Ive found a set of 22" and 9" wide wheels to BMW (lugs 5x120). offset +10. Centerbore 74,5.
Wonder if with special adapter/spacer from 114, 3 to 120 - they will fit to my FX.
Adapter is 25mm thick so offset will go to 35mm ? Am I right?
maybe you can be the first herrrrrrrra frush fx...
Coilovers, stretched tires, some poke and lotsa negative camber can make it fit
took me some time to understand this and it would be like add 50mm spacer to oem wheels. ;)
no way to work!
sry guys for bother ;)
So now looking for ML wheels with 5x112 studs and 40mm offset. ;)
Yup, that offsest is no good even for redrilling.
I am actually about to fit some 5x120 9.5 width et35 rims on my car with some adapters. The smallest adapters I have found are 19mm... so that would bring my offset to 16mm. http://www.motorsport-tech.com/
