Service Engine Soon light?
lg396485
Plainsboro, NJ
Several times my service engine light comes on along with the VDC and TRAC lights and everytime my fx wont go over 2000 rpm. Does anyone know what I can do to solve this issue. Ive had it repaired at the dealer twice now for the same issue yet it still keeps coming back. Very frustrated and would like some advice.
looks more like a problem with your throttle body causing your car to go into limp mode. the sensors seems to have gone out of whack. did you or anyone work on the throttle body recently? if you can get get an OBDII scan and bring us the code, we can help you more.
If the dealer fixed it before and you are still having the same issue then you should take it back to the dealer and have them correct it properly. And it should be on their dime.
If is the same problem as before they should fix it even tho your FX is out of warranty.. Is a problem they thought they fixed but they didn't.. If they give you problems about it call Infiniti consumer affair. They will open a case for you.
+1, yes. You should have your prior service receipts on hand as it will state what your issues were just in case, but it should also be documented in your service history in their system.
Definitely go after Infiniti but go to an auto parts place and ask them to scan your ECU for codes, At least you'll have some idea what you are dealing with.
