the1obster
- OC
Hey guys, Just installed front/rear brake pads and rotors (posi quiets and blank rotors. rotorpros gave me a great deal btw). I have a slight "scratching" sounds that is going a way slowly, not not totally gone after 2 days of driving but slowly. I also heard a few "clunking" noise while cruising at slow speeds (10 mph). Today is the third day and both noise are gone. Not a sound from rotors or pads. This is the first time i installed pads/rotors. So my question is:
1) is there an INNER and OUTER pads for a 2006 FX35?
2) there is a little spring/clip on the bracket that holds the pads in, does the little clip on the spring go into the oval loop that is the wear sensor that is attached to the break pad itself?
3) does the wear indicator have to be on the inner side of the rotor and pointed down.
let me know guys dont want to drive the fx if i installed it all wrong
