Deals on other Sites
Status
Not open for further replies.
Time to buy those osram bulbs! $185 a pair. then use 10% coupon for it! Or do a group buy and use the 25% off coupon!
The legendary Black Friday Sale at The Retrofit Source is back!
Check out the flyer:
http://www.theretrofitsource.com/blackfriday/
Store-wide Deals:
10% off any order $100 or more! Coupon = TRSgiving15
15% off any order $200 or more! Coupon = TRSgiving20
25% off any order $300 or more! Coupon = TRSgiving25
! Shop and combine these deals with other specially priced setups below !
Projectors:
- Morimoto Mini H1 5.0 Bi-xenon Projectors: $90!
- Morimoto Mini D2S 2.0 Bi-xenon Projectors: $80!
- FX-R 3.0 Bi-xenon Projectors: $110!
- Lexus RX-AFS/TSX-R Hybrids: $175!
Complete Retrofit Kits!
- Bi-xenon Morimoto Mini H1 Stage III Kits: $270!
- Bi-xenon Morimoto Mini D2S Stage III Kits: $295!
- Bi-xenon FX-R Stage III Kits: $315!
Other Retro Gear:
- Morimoto Elite HID Systems: $125!
- Osram D2S CBI and SVS bulbs: $185! (yes, they're on sale!)
- New Black Series Clear Lenses! $25!
Wow, nice deal. Made me spent some money there. Utilized the 25% coupon code for some TSX-R clean lens and Osram CBI 5000K bulbs.
I'm def going to be purchasing the fog light HID kit and try to match the other HID bulbs I purchased from them
I'm wanting to change out all my bulbs and get an HID kit for the fogs... wondering if I should do this now...
Just so you know, Marek used oem lenses and modified the heat shield to get the cutoff you see now.
Adding a tsx will probably make it even better.
5000k is the way to go, nice choice.
Just read through a billion threads about HID fog kits, and I'm not sure what is best to do, so I'll probably hold off.
Does anyone here did the HID projector on their fogs? Is it worth it? My fog OEM starts to clound with those tiny rock chips.
Tired, but the aftermarket direct fit angel eyes with projector fogs are horrible.
The projector lens is not good and made for a halogen bulb.
You're better off trying to retrofit a morimoto projector or other small projector in the oem fog housing or similar.
^ thanks Ed. I was looking at some items on fleabay but the reviews on them are least to be desired.
Let me rephrase, they look cool. But the light output even with a HID kit is worse than OEM fogs.
You also need to buy lamin-x for the glass as they crack easily.
For looks, they work.
I'm confused...Ed you are saying the HID morimoto kits are worse light output than the original fog lights on the FX? And they crack easier?
First time I'm hearing this....
I was about to buy the H8 Morimoto elite HID system.
I think hes talking about aftermarket projector housings for first gen fog lights are horrible. They a re made for halogen bulbs but when you retrofit with hid bulb, output horrible.
^ ok, so the H8 HID fog system should be brighter than the OEM just to be clear...I would hate to spend money and convert if it's not better all around.
---------- Post Merged at 09:37 PM ---------- Previous Post was at 09:37 PM ----------
I really like the output with my oem hid fogs...
smarty pants....no oem hids.
Status
